well the seat test is nothing more than a seat test.
the only way to know is to go and ride. You can always get another spring.
Depending on the tune from push, you shock could have VERY different compression characteristics compared to the DHXA (?) that you took off. I found a stock Vanilla to feel much more active-bottoming excessively at first and needing 50 lbs more spring rate than recommended. Now with 4 clicks of compression for regular riding and 6 clicks for lift-access, I am in heaven.renton said:hi there thanks for the replies!!
can you try and explain to me how they feel different compared to an air shock as this is my first coil shock so im keen to learn.
the coil shock is a fox dhx5 coil which has been pushed and came off another enduro the same as mine.
my enduro is a 2006 enduro pro.
cheers
steve
