Hi guys...
So need some assistance. Looking at the following and need some guidance, exactly how much of the physical build i will do myself is to be seen, there will def be assistance, but would like to do most of the buy/decisions myself to learn.
Sites from which I can purchase would be appreciated.
Phase #1 wheels will be build onto Aluminium rims with a ERD of 594mm (See attached)
Hubs, Chris King ISO Boost, front and rear (32 hole)
Front : Flange Diameter Drive Side & Non-Drive Side (mm) 57.4mm
Front : Center to Flange Drive Side (mm) 26.9
Rear : 57.4
Rear : 24.0
Rear is +5mm offset
Phase #2 wheels will be rebuild onto carbon, this will be either DeeD carbon or FHR930C 30mm depth/30mm wide carbon mtb rim 29er - Xiamen Carbon Speed Sport Goods Co.,Ltd
when doing this page #2 rebuild, I want to use the same spokes, will require to cut them shorter (ERD 584mm and rethreading).
Comment on these rims would be appreciated,
I'm looking at a 2 cross Sapim spokes (all my other bikes always build with them), not sure between normal or double butted.
Whats the benefit of say the double butted.
Can you assist in figuring out the spoke length. please point me to web site that can assist.
Can you assist in deciding which nipples,
If I look online some comments are to put little bit of oil into nipple as tightening it, assist long term.
I'm a noob so please be gentle.
Tyres will be Maxxis Ardent Race 2.35 front, Ardent race 2.25 rear, or (Fav wheel combo) Vittori Barzo 2.35 front Suguaro 2.2 rear
Fork is a Rockshox SID 29er Boost.
Frame Pyga Stage
G
Rear : 57.4
Rear : 24.0
Rear is +5mm offset
Frame Pyga Stage
G
