Would you dialed wheel builder types help me out?
I'm building a lightweight xc wheel set for my daughter and, it being my first time building wheels, wanted to double check a few things. I put the spoke calculator values from the DT Swiss site below.
Rim is a carbon 27.5 asymmetrical, 275 gram, 28mm x 22mm internal x 25mm tall, with a 2.6mm offset and 555.6 erd. Spokes will be 1420's, not aerolite's as listed below.
Do I need to adjust spoke length for the asymmetric offset? Are the 14mm nipples appropriate for the build?
Thanks in advance!
Thanks in advance!
