Wolf Tooth has a new modular multi-tool that covers all manner of basic trailside repairs and then some. The 8-Bit System builds on the success of the company's 8-Bit Pack Pliers with additional functionality to get riders out of most jams. Read on for details from Wolf Tooth.
Related: Best Multi-Tools For Mountain Biking
The 8-Bit Chainbreaker + Utility Knife Multi-Tool and the 8-Bit Tire Lever + Rim Dent Remover Multi-Tool join the 8-Bit PackPliers to complete the system.
The three neatly nest together using magnets and clever machining for compact storage. The 8-Bit Chainbreaker + Utility Knife Multi-Tool has three functions. It has a chain breaker on one end and a retractable utility blade on the other.
The chain tool is operated by an included 3mm hex L key that doubles as a tire plug inserter. A machined slot fits the L key and converts the entire multi-tool into a tire plug inserter, with the forked end of the L key extending outward.
The handles of this multi-tool slide open to provide storage for tire plug inserts, a valve core, and a spare mini utility blade.
The 8-Bit Tire Lever + Rim Dent Remover Multi-Tool has two functions. A slender, ergonomic plastic tire lever is on one end opposite of a machined aluminum rim dent remover. The tire lever will work with all tubed and tubeless tires, while the rim dent remover is compatible with all metal rims.
The 8-Bit System takes its name from the 8-Bit Pack Pliers, as the two new multi-tools have the same silhouette and nest neatly together. The 8-Bit Pack Pliers Multi-Tool has 17 functions. On one end of the multi-tool, an 8mm swivel head serves as a driver for the bits that are stored inside: flat head #3.5 and phillips #2 screwdriver bits; 2, 2.5, 3, 4, 5, and 6mm hex; and T10 and T25 Torx-compatible bits.
A spoke wrench and valve core wrench are stored on the back and a rasp is on the inside of the upper handle for clearing sealant from valve stems. On the other end of the multi-tool, pliers for master link installation/removal and tightening/loosening of valve stem nuts.
These tools were designed, engineered, and machined at Wolf Tooth in Minnesota from 7075-T6 aluminum. These new multi-tools can be purchased individually or as a complete 8-Bit Kit One set that includes all three.
- 8-Bit Kit One: $139.95 USD
- 8-Bit Pack Pliers: $69.95
- 8-Bit Chainbreaker + Utility Knife: $69.95
- 8-Bit Tire Lever + Rim Dent Remover: $19.95
