Today, RockShox introduced the latest revision of the Lyrik. It is a big-hit single crown fork that can now take on even more with configurable travel from 160mm to 180mm. The Lyrik helped bring RockShox back into the limelight, but it has not been updated in a while, offering only 26er sizes with older dampers. Recognizing the popularity of longer travel forks without having to go to a dual-crown fork, RockShox put all their new technologies in the Lyrik and upped the travel to 180mm.
This fork gets the fabled RCT3 damper and all the new options, such as Torque Caps to increase stiffness and Boost 110 to allow stiffer wheels and Plus size tires. The weight is quite respectable too at 2,005 grams or 4.42 lbs.
The RockShox Lyric is a big-hit single crown fork that can now take on even more with configurable travel from 160mm to 180mm.
The RockShox Lyric is a big-hit single crown fork that can now take on even more with configurable travel from 160mm to 180mm (click to enlarge).​
RockShox Lyrik
The Lyrik fork has been updated to be stiffer and have a longer travel option all the way to 180mm on the 27.5 and 29er wheel sizes. The 35mm chassis has been stiffened as the fork has been updated with the Torque Cap and Boost 110mm compatibility. It is available in 160mm-180mm travel options for 27.5" and 150mm-160mm for 29".
Specs
RockShox Lyrik Specs
Pricing and Availability
  • Lyrik RCT3 Solo Air, all, travels and configurations: $1,030.00 US
  • Lyrik RCT3 Dual Position Air, all AM wheel sizes, travels and configurations: $1,110 US
  • Available: October 2015
The new RockShox Lyric  has been updated with the Torque Cap and Boost 110mm compatibility.
The new RockShox Lyric has been updated with the Torque Cap and Boost 110mm compatibility (click to enlarge).​
New Technologies
  • 15×100 and Boost 110 (15×110) versions
  • Torque Caps compatible (15×100 and Boost 110 versions)
  • Tapered legs, taller stiffer brace - chassis optimized for stiffness and light weight
  • New retuned Solo Air spring with additional negative volume for a plusher initial stroke
  • Bottomless Token tunable in both Solo Air and Dual Position Air configurations
  • SKF wiper seals - lower friction better sealing
  • User tunable rebound damping via internal shims (same as BoXXer)
Proven Features
  • 35mm chassis
  • Charger Damper with new SKF cartridge seal - reduced friction and extended service intervals
  • Solo Air and Dual Position Air
  • Fast Black upper tubes
Continue to page 2 for the RockShox Yari fork and a full photo gallery »
The RockShox Yari is a reliable, more affordable package with more travel configurations.
The RockShox Yari is a reliable, more affordable package with more travel configurations (click to enlarge).​
RockShox Yari
The new RockShox Yari is here with more travel configurations starting at 120mm travel and all the way to 180mm. It is more affordable as well at $700. Weight is a respectable 2,023 grams compared to the Lyrik's 2,005 grams. Instead of the Charger Damper, it will have the Motion Control Damper with less adjustability.
Specs
RockShox Yari Specs
  • Yari RC Solo Air, all wheel sizes, travels and configurations: $700 US
New Technologies
  • Tapered legs, taller stiffer brace - chassis optimized for stiffness and lightweight
  • SKF wiper seals - lower friction and better sealing
  • New refined Motion Control damper: Rapid Recovery rebound and Re-tuned high speed compression to match Charger
The RockShox Yari weight is a respectable 2,023 grams compared to the Lyrik's 2,005 grams.
The RockShox Yari weight is a respectable 2,023 grams compared to the Lyrik's 2,005 grams (click to enlarge).​
Proven Features
  • 35mm chassis
Unique to RockShox: Torque Caps
  • Larger interface between dropout and hub end cap results in stiffer front end - increased steering precision, better bike handling, more confidence
  • Lyrik and Yari are Torque Cap compatible in both 15×100 and Boost 110 (15×110) models
  • All RockShox 15x110mm forks are Torque Cap compatible (SID, Reba, Pike, Lyrik, Yari)
  • Torque Caps are compatible with the following SRAM wheels and hubs: Rise XX, Rise 60, Roam 30, Roam 40, Rail 40 and X0 hubs
For more information visit www.sram.com/rockshox.
