Canyon Stoic
The all-new Canyon Stoic hardtail looks like the perfect gateway bike for new mountain bikers.​
Having the best time on an MTB ride isn't always dependent on how flash your gear is. Canyon's new Stoic is proof that you can rip down your favorite trails with a huge grin on your face without the words "kinematic" or "shock setting" ever crossing your mind.
Related: Canyon Spectral 29: Everything you need to know
Canyon Stoic Hardtail Highlights
  • 65° head tube angle / 75° seat tube angle
  • Sizes M-XL designed around 29" wheels and 140mm forks
  • Sizes 2XS-S designed around 27.5" wheels and 150mm forks
  • 29 x 2.6" tire clearance
  • 27.5 x 2.8" tire clearance on 27." versions
  • Two builds available in the US
  • Price range: $1,099 - $1,799
  • Available in early 2021
  • For more information visit www.canyon.com
Canyon set out to produce a versatile, capable hardtail to take on anything, without it breaking the bank. A bike that makes sense whether you happen to be a young rider on a budget, a newcomer wanting to dive into the gnarlier end of MTB, or a seasoned shredder looking for a fun hardtail to add to your stable. They ended up with an all-new, alloy hardtail, featuring progressive geometry, and rock-solid components. It's available in a huge size range, with 29-inch wheels for taller riders and a 27.5-inch setup for shorter riders.
Related: The Best Mountain Bikes Under $1000
Canyon Stoic Geometry
Canyon Stoic
The Stoic is designed to keeps things fun-whether pushing limits on steep technical trails, playing around at the local pumptrack or just riding through your neighborhood. Sitting among Canyon's Category 4 quiver of bikes, it's been tested and approved to withstand the same punishment as the company's enduro rigs. Combine this with the low-slung top tube and low maintenance design, and you wind up with a tough and reliable hardtail that's the perfect training buddy as you hone your riding skills.
Related: The Best MTB Frame Protection
Canyon Stoic Models, Pricing and Availability
The Stoic line-up in the US features two models. All 29er options (sizes M-XL) are fitted with 140mm travel forks and all 27.5-wheeled bikes (2XS-S) get 150mm travel forks.
Canyon Stoic
The entry-level Stoic 3 packs a lot of value into its budget-minded built.​
At $1,099, the Stoic 3 is the more affordable option, featuring the same 6061-alloy frame as the rest of the range, it has everything a trail bike needs, including an Iridium dropper post, wide-range SRAM SX Eagle drivetrain and a Rockshox Recon RL fork.
Canyon Stoic
The Stoic 4 is the top-end build for US riders.​
At the top of the tree sits the Stoic 4 at $1,799. Fitted with parts the discerning hardtail rider will appreciate, including the bump-gobbling Rockshox Pike fork and swank Canyon G5 cockpit, our top-shelf Stoic punches way above its weight out on the trail.
Both models of the Stoic will be available in the US in early 2021. Visit www.canyon.com for more information.
