it depends on the course dude so no one can really help you. but you might wanna set it up good for pedalingLucky13 said:Was wondering how would one set up suspension for a DH course? I know it should sag about 30-40%, but what about rebound and compression? Cannot proide any info on the course as I don't know myself.
yup, and never make a change before a race run...big no-no.....COmtbiker12 said:I'd just leave it the way you have it. If you're gonna be doing practice runs tinker around ot see how you like it.
i know. i really do. only been to 4 races this season and windrock will be number 5 and my last one this season. i need to get out to way more races. but its pretty hard when i cant drive or anything.COmtbiker12 said:Maybe you just need to come out west for some races Jason.You'll find that pedalling a course that pros are getting 4-5minutes on is a necessity.
does he even have a chainguide? i know this messed me up on my first race. i dropped my chain half way down the course and had to coast the rest of teh way. still got third in my class thoughMoriority said:This might sound like a dumb answer to some but it is true. Suspension set up will not make you or break you on your first few dh races. But your chain guide will do you in. Make sure it is set up right and not half assed. It might work while you just ride around but for some reason when you race they get hosed up. That is one of the biggest problems I have seen with new racers. I had problems with my first guide and so did just about everyone I know. Even if you bought a good guide make sure it is right and you will be a happy guy at the end of your race.
If you have a bashguard instead of a big ring, here's a trick I used to use. Set your limit screw on your FD so that when you're in 3rd gear your chain is still on the middle ring but rubbing when you're in the larger gears in the back. Then as you accellerate and downshift in the back, rubbing goes away, and you've got a much tighter FD holding your chain on than if you just leave it normally. Also, if you drop your chain you can downshift the front down to 1, and then upshift as normal while pedaling and it'll usually pick the chain back up. THese are just stopgap measures you can try this weekend, nothing substitutes for a good chainguide. Haven't tried Truvativ's, but am a pretty big fan of E13. Anything is better than nothing, though.Lucky13 said:Don't have a guide yet, thus, I expect no problems accosiated with it. Still trying to save up for one. Is Truvativ any good?
