Yes... thinking about options on my build up. Want to know the spec build. I would think 203 would be pretty big for specs..dog said:do you mean what rotor size comes with the spec kits?
So I bought some AVID Codes 203/185 and when I got them, did some more research and have decided they are total overkill. I weight 185 geared. Trying to trade them for some Elixirs.... Going 185 F/R. Think that's best for my needs and weight savings. I would save almost a 1/2 pound! I hear the Codes are specifically for downhill.gticlay said:I'm running 203mm F/R with 4-pot Saints. Great if you weigh more than 200lbs.
Well, these don't have a sticky lever and are pretty darn good. Carbon levers with an extra in case you break one. Lemme know, they should be more powah than any 185lb rider could need.daugela said:I need to sell these first. Running out of cash. I had the Strokers on my 08 Reign. Still have 1 on there, the other broke. They were pretty good. But I had the sticky lever issue that Hayes had on their first batch in which they sent out the fix it kits....
