I call that cool not dumb.Severum said:That would be Ed. Dumbass almost dropped it off a retaining wall with no helmet. What are great time.
I don't understand why he's running such low pressure?Severum said:This pic shows how low the pressure was.
Well, yeah, I realize that. Just doesn't make sense to me to ride them that low when you don't need to.Severum said:Lower pressure helps flatten out the contact patch for more surface area on the ground...
Your right, I just missed the learning curve.radair said:Well, yeah, I realize that. Just doesn't make sense to me to ride them that low when you don't need to.
Very cool insert shot Severe'em, I think we should advise our fellow CNH members to wear a helmet, we can't afford to lose any members.Toddski said:Radair you dope! You run low air pressure to get an extra good work out and burn lots of Holiday calories, pushing those blobby meats around on those heavy hoops of death is a sure gut buster! Plus by running such low air pressure you have the added bonus of everyone standing around you doing the "I'm freezing my balls off" dance when your always fixing a tube in zero degree weather, that's always fun.
I'm just kidding. The real reason you run such low air pressure is that it adds float in snow dummy. You every see that movie Star Wars, probably not, but this guy named Luke has the land speeder that hovers above the ground...well same concept the less air you put in a massively heavy wide tire it will just make the bike float, almost hover above the powder, its amazing! You should try it you big dummy.
Being as brain dead as I am my risk is minimal. Please, everyone else....wear your helmets.Severum said:I told him he should sway away from the drop due to lack of helmet, then gave up and bugged him to do it.
If my dream works out we will have a ride up on a shuttle and ride the 4 miles down on our bikes...multiple times.Severum said:Ed wants us to climb Mt K. this winter. What do you think about that Mink, possible? Is it a wise idea? It should be fun if we give the ride enough time.
Ditto.Severum said:Well, dream on then... make it happen.
Well, dream on then... make it happen.minkhiller said:If my dream works out we will have a ride up on a shuttle and ride the 4 miles down on our bikes...multiple times.
If all else fails your plan is good with me, it's all home to me.Locotiki said:Ditto.
