New member bike pics
Hey all, I`m new on here so for my first post I thought I would share a few pics of my custom 2009 Felt Redemption 3. I`ve chucked a few bits on there to personalise it, hope you enjoy the pics.
Frame:
Felt Equilink “Aggresive All Mountain” Full Suspension, 6061 Double-Butted Aluminum Front Triangle & Sub-Frame 165mm Travel, Oversized 1.5 inch Head Tube & 34.9mm FD, 34.9mm SPC, Seat Tube, Standard 135mm Axle, Compatible with Felt ISCG Mount, Replaceable Derailleur Hanger, Disc-Brake Specific
Rear Shock:
Fox Float R XV Air 8.5 × 2.5, Pro Pedal, Rebound Adjust, With Custom Valving, 220 Grams
Fork:
RockShox Domain 318iS U-Turn, 115/160mm Travel, Motion Control Damping with Integrated Speedstack, 20mm Thru Axle, Disc Brake Specific
Front Derailleur:
Shimano Deore FD-M531 Bottom Swing Dual Pull
Rear Derailleur:
Shimano SLX RD-M662 “SHADOW”
Shifters:
Shimano Deore SL-M530 Rapidfire Plus 27-Speed
Chainset:
Truvativ Firex 3.1, 2-Piece Crank Giga-X-Pipe External Bearing Design, Cold-Forged AL-66
Chainrings:
32/22 Tooth chainrings with Carbon Fibre bash guard
Bottom Bracket:
Hope Stainless MTB
Cassette:
SRAM PG-950, 9-Speed Cassette, 11-32 tooth range
Chain:
Sram PC-951 (9-Speed) with custom chain tensioner
Front Brake:
Avid Elixir 5 Hydraulic, Rotors: 203mm
Rear Brake:
Avid Elixir 5 Hydraulic, Rotors: 185mm
Brake Levers:
Avid Elixir 5
Handlebars:
Felt XAM All Mountain Handlebar Butted Oversize 6061 Aluminum, 31.8mm clamp diameter, 25mm Rise, 8 degree bend with 4 degree sweep, Width: 680mm
Stem:
Felt XAM All Mountain stem, 3D Forged Alloy, 4-bolt design, 31.8 Bar Bore
Headset:
1.5 inch FSA Big Fat Pig with cased bearings
Grips:
Hope Grip Custom “Lock-On” Design with Alloy Ends Single-Density Extra-Soft & Sticky Durometer, 130mm Length, 30mm OD red
Rims:
WTB Dual Duty FR Disc Doublewall, 26 × 1.5 × 32 hole, 28mm Width Presta Valve with Eyelets Black Anodized
Front Hub:
Felt 20mm Thru Axle Cold-Forged Aluminum Body, 32 hole Disc Brake
Rear Hub:
Shimano FH-M475, Non Series 6-Bolt Disc Brake, Aluminum Cassette Type (8-9-Speed), Steel Freehub Body, with Black ED Steel Quick-Release Lever
Spokes:
Sandblast Black Stainless 14G, Brass Nipple
Front Tyre:
Maxxis Minion DHF Triple Compound 26 x 2.5
Rear Tyre:
Continental Mountain-King 26 x 2.4
Saddle:
SDG Bel Air Saddle Wide Nose, Broad flat rear with soft tissue relief channel. Rear “Jewel Safe” crush zone, Kevlar protected edges, Stitch free top, smooth leg chafe protection. 7mm Rails
Seatpost:
Raceface pro DH with Micro-Adjust, 100% Black, 6061 Low-Profile Forged Head & Extruded Rail Clamps, 30.9×350mm
Seat Binder:
Felt QR Seat Clamp Cold Forged + CNC, 6061 Aluminum 34.9mm
Bottle holder:
KTM in white and orange
Bottle:
Hope 550 ml
Lights:
Twin Cree Q5`s up front, 5 LED rear
Pedals:
Shimano Saint MX80
Chainstay protection:
Equilink cloth
Seatstay protection:
Lizard Skins cloth
Speedo:
Cateye 14 function wireless
Mudguards:
PPE between fork legs, Mucky Nuts short fender up front, Fox racing short rear
Cable covers:
White gear cable covers by Felt
Extra graphics:
White Felt graphics
Green Raceface graphics
Removed:
Rear spoke protector
Front and rear wheel and frame reflectors
Rider:
43 yrs old slightly crazy Welsh bloke
If you got this far thanks for reading the post.
