Oh, BTW !!
25.5lbs (the whole thing)!
Zion Rasta said:
Zion Rasta said:My female yeti 575 was freezing in the garage so I brought her inside for some lovin'
She says "I want to wish you all a merry X-MAS"! The HOPE skewers said "who's your bling daddy now"?
PS Desert Yeti - Take me for a ride in New Mexico, I am freezing my a$$. I'll buy you dinner...
If I may. I have some ideas for weight savings for you. Your stem looks pretty heavy. Weight Weenies has the Easton EA70 welded 100mm x 10 deg. at 215 grams. You could get a Syntace F99 260 105mm x 6 deg for 107 grams, a Ritchey WTC Mountain V2 100mm x 6 deg for 127 grams, or an Extralite Ultrastem 100mm for 106 grams. These stems are half the weight of the Easton.Zion Rasta said:25.5lbs (the whole thing)!
Thank you for the ideas. I do have lighter stems - Thomson 100mm, Easton MG 110mm, Ritchey wcs 110mm. All those are very light 140g to 180g. But the truth of the matter is that I purposely put that tank of a stem on the bike. It matches the frame and it clamps very good to carbon. It is heavy, but it does not flex at all. It feels great and secure downhill. So I will not be looking at weight savings there.mtnfiend said:If I may. I have some ideas for weight savings for you. Your stem looks pretty heavy. Weight Weenies has the Easton EA70 welded 100mm x 10 deg. at 215 grams. You could get a Syntace F99 260 105mm x 6 deg for 107 grams, a Ritchey WTC Mountain V2 100mm x 6 deg for 127 grams, or an Extralite Ultrastem 100mm for 106 grams. These stems are half the weight of the Easton.
I know you just got those cool bling Hope QRs but they weight 114 grams, compared to bolt on for 65 grams and only $12. They will be stronger than QRs, key for your front end.
Also foam grips. Titec pork rinds are only 19 grams.
Just some ideas![]()
looks so shiny......do you even ride that thing mijo?Oni said:"Little brake bolt clippy so they won't rattle off and I'll lose my brakes and I'll die a horrible death" things?
Nice job. I'm curious to know what you're running for parts to get it so light. Could you enlighten the rest of the Yeti Horde?
Thanks,
Oni
Man it's cold here too. Might get to 40 today if we're lucky. Last time I rode it was about 30 degrees not counting wind chill and there was a lot of wind chillZion Rasta said:My female yeti 575 was freezing in the garage so I brought her inside for some lovin'
Desert Yeti,DesertYeti said:Man it's cold here too. Might get to 40 today if we're lucky. Last time I rode it was about 30 degrees not counting wind chill and there was a lot of wind chillI got kinda sick after that ride.
Here is what I got - Nothing fancy, but it does the trick:Oni said:"Little brake bolt clippy so they won't rattle off and I'll lose my brakes and I'll die a horrible death" things?
Thanks,
Oni
Dude,eatdrinkride said:63 degrees here in the Phoenix area at 5:30pm...Brrrrr (insert "shiver" here)
I might have to wear full finger gloves by next week but I will never give up my riding shorts for any spandex looking leggie things, lol.
Dude,mtnfiend said:That isn't anything fancy. A good mix of XTR helps and the light wheelset, but nothing too exotic. Now mine weighs in at 30.5 last time I weighed it but I know I've got a few boat anchor parts. Like my cranks and tires. But the is a bad a$$ bike.
Components:
Headset - Chris King
Handlebar - Easton or Answer ProTaper 2' rise
Stem - Thomson 90mm x 0 deg
Front Brake - Hope M4 w/ 160mm rotor
Rear Brake - Hope Mini w/ 140mm rotor
Levers - Hope
Shifters - XT triggers
Fork - RS Pike Team
Rear Wheel - King ISO Disc - Mavic MX819 - DT 14/15/14 Comp
Front Wheel - Hugi Freeride 20mm - Mavic MX321 - 14 Comp
Rear shock - Fox RP3
Frame - Yeti 575 Black Anno M 2005
Rear deraileur - XT
Front deraileur - XT
Crank - Race Face Evolve DH 32x22 w/ Truvativ Lexan guard
Cassette - XT 12-34
Chain - SRAM PC 99 Hollowpin
Pedals - Crank Bros. Mallet
Seatpost - Thomson Elite
Seat - 10 year old Bontrager seat
Tires - Kenda Nevegal 2.35 Dual Compound
QR's - Bolt on rear, Maxel front
Seat clamp - HOPE
Grips - ODI Ruffian Lock Grip
Total: 30.5
Well I'm riding Barker Dome next week which is a rediculously techy trail. It's like 14 miles outside of my town. 13 to 14 miles of rediculously techy ascents and nasty downhills with only maybe a mile of smooth singletrack. It was 4 degrees here today at 8:30 this morning and is only about 18 now at 11:50 and with windchill its flippin cold today. Hopefully be warmer next week. I say we go meet eatdrinkride.Zion Rasta said:Dude,
I used to live in TEMPE back when the Refreshments were a hit band (circa 1994). Could you downhill Camelback with your 575?? Sedona and Flagstaff are kick a$$!!!!
Post a photo of your mojo. Sounds cool!Oni said:Mojo- Slightly raunchy, nekkid female (in)action figure....
Tony bro,antonio said:hey zion - you have enough miles on the wheelset to post a review? i've heard a lot of good things about mike (great prices, excellent wheelbuilds, awesome post-sale customer service), and was considering the same wheelset, but have read that the rear hub has a tendency to fail.
btw, really nice build. cool skewers.
ant
