Alright, I have 2 sets of Large Marge rimmed wheels, 1st generation, I guess they're now considered their DH rims.
1 set has Endomorphs, the other Gazzaloddis.
1st attempt- Gorilla tape, removable-core Presta valve section, home made sealant (Wadester's formula: 1 pt. latex mold builder, 1 pt. Slime automotive, 1 pt. ethyl glycol, 2 pt. water.) "Painted" the inside of the Endos with latex mold builder.
Got the beads to set on the Gazzis without a problem, but needed a strap around the circumference of the Endos to get the bead set.
The Gazzis had apparently been removed or replaced using a screwdriver or something like it, because there was some damage to the bead rubber. These are not holding, even using a fair amount of sealant shaken into the area, but slowly improving.
The Endo wheelset is leaking at the rim seam at any pressure above 5 psi.
Next step today is to try and find some 24" Presta valved tubes, hopefully (but not unexpectedly) with removable cores. I'll split them down the length and try using them as "Stan's-style" rim strips.
I'll post results later. If anyone has experience with this stuff, feel free to add.
Los
Los
