Fall is upon us. Leaves are changing color and the days are growing shorter. It's time to start thinking about bundling up for chilly rides, doing a bit of routine maintenance after a long summer on the trails, and gearing up for night riding. We've rounded up great deals on all the gear you need to have a great time on the trails this fall.
FOUNDATION 613H8 HEX WRENCH TOOL SET - Save 50%
The shop-grade Foundation 613H8 Hex Wrench Tool Set includes six L-shape hex key wrenches (2-6mm), and an 8mm bit that attaches to the 6mm wrench. The 4/5/6 mm wenches feature a ball driver tip on the long arm for hard to reach bolt heads and a straight tip on the short arm for high torque applications. The Foundation 613H8 Hex Wrench Set includes a handy portable tool organizer/holder for easy access and portability.
Original Price: $6.95
Sale Price: $3.48
Buy Now
LIGHT AND MOTION URBAN 1000 FC LIGHT - Save 35%
Light and Motion's Urban 1000 Fast Charge Light has all the features riders look for in a light, giving you a bright light source that keeps you seen while helping you see what's in front of you. A unique design illuminates not only what's in your path, but what's beside you as well with openings on each side. It charges quickly with a standard micro USB, and delivers 1000 to 500 lumens of steady light, depending on the mode you prefer. It includes mounts that attach to your handlebars, helmet, or standard GoPro mount. With an FL-1 certification, it designed to survive crashes and water, so you know you can rely on it even in the worst case scenario. At only 121 grams, and 4" long, its compact and easy to use.
Original Price: $120.00
Sale Price: $78.00
Buy Now
MAXXIS MINION DHF 3C/DD 29" TIRE - Save 10%
Minions aren't just cute, yellow cartoon characters, they're also some of the best mountain biking tires on the market. The Maxxis Minion DHF is one of the most sought-after tires and has become the benchmark for riders wanting maximum control in loose and muddy conditions. It features directional ramped center knobs that provide low rolling resistance, signature channel cut side knobs that provide excellent cornering traction, Double Down casing that provides additional sidewall protection, and 3C triple compound with a harder base rubber layer and two progressively softer top layers to maximize performance. This tire is perfect for the trail, all-mountain rider or enduro rider looking for optimum performance in loose, medium and wet conditions.
Original Price: $90.00
Sale Price: $81.00
Buy Now
ROCKSHOX REVERB STEALTH 170MM - Save 51%
Its legendary performance has been improved upon. RockShox turned the Reverb Stealth into a whole new animal with re-engineered internals. It was put under a microscope and scrutinized right down to the tiniest seal. Everything that could be updated and improved upon was and now passes even the most brutal durability tests.
Original Price: $349.00
Sale Price: $169.00
Buy Now
WTB VENTURE 700C TIRE - Save 10%
When you're riding offroad, the type of tires you use on your bike have a significant impact on your performance and ride quality. The WTB Venture 700C Tire delivers optimal performance across the widest range of conditions. It is designed with elevated centerline ridges that provide excellent climbing traction and two rows of outer knobs that provide confident cornering capabilities. This tire will be the tire of choice when you're out riding the gravel or going on an adventure.
Original Price: $59.99
Sale Price: $53.95
Buy Now
AVID BB7 MTB DISC BRAKE - Save 28%
The Avid BB7 MTB disc brakes are some of the best mechanical disc brakes on the market today. The Avid BB7 brakes are super reliable and offer compatibility with long pull levers. Avid Tri-Align Caliper Positioning System (CPS) is easy to use for getting the perfect alignment. The strength of the Avid BB7 brakes will bring you peace of mind as you're zipping down the trail.
Original Price: $61.00
Sale Price: $43.99
Buy Now
EVIL WRECKONING LB DEORE JENSON USA EXCLUSIVE BUILD - Save 27%
This Jenson USA Exclusive version of the Evil Wreckoning LB comes with an expertly picked Shimano Deore 1x12-speed drivetrain. This includes a cassette that has an ultra-wide-range 10-51T cassette that makes climbing and riding in rough terrain a breeze. Shimano Deore hydraulic disc brakes provide confidence-inspiring stopping power so you can descend under control. E*Thirteen LG1 wheels are paired with E*Thirteen TRS Plus All-Mountain tires that can be set up tubeless for a smoother ride, better traction, and fewer flats. With the SDG Tellis Dropper Post, you'll be able to quickly lift and lower your saddle with the press of a lever. This will ensure you can climb efficiently and descend safer with a lower center of gravity.
Original Price: $4,800.00
Sale Price: $3,500.00
Buy Now
FOUNDATION MOUNTAIN PRESTA BIKE TUBE - Save 25%
Tubes rank as one of the least exciting parts of a bike to think about, but they are pretty dang essential and deserve some consideration when deciding which ones to purchase. Foundation Mountain Presta Bike tubes offer a great bang for your buck and come in a variety of widths to fit your individual needs. When the tube you're rolling on goes flat, you don't roll. If you don't have a replacement handy, your walking, not rolling, and at this price there is no reason to not have a spare handy.
Original Price: $7.99
Sale Price: $5.99
Buy Now
LEZYNE KTV DRIVE PAIR - SAVE 20%
Alternate Image
Original Price: $39.99
Sale Price: $31.99
Buy Now
RACE FACE HALF NELSON LOCK-ON GRIPS - SAVE 20%
The Race Face Half Nelson grips are designed to give you a super tacky thin feel straight out of the box. Don't hassle with purchasing thick grips that need to be broken in.
Original Price: $23.99
Sale Price: $20.39
Buy Now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
