1 - 7 of 7 Posts
· Unicycles are for clowns
Anyone on here ride a F4000 SL? Is the only difference between a F4000 SL and F2000 SL the "Si" crankset (same tubing)? :confused: Can you buy a F2000 SL frame only, no fork? Thanks! :)
· Registered
for 2006?
Do you mean a current model year? These bikes are speced so different that the only common part is the frame. (along with the tires, pedals, headset, and stem.) That is it.
You can buy an Optimo frame fram your dealer.
F4000 SL Specs Back Geometry
Frame Optimo Si
Fork Lefty Speed Carbon FOX TerraLogic TT, 110 mm
Rear Shock N/A
Rims Mavic CrossMax SL UST
Hubs Mavic CrossMax SL UST
Spokes N/A
Tires Maxxis Larsen TT UST, 26 x 2.0"
Pedals CrankBrothers Egg Beater
Crank Cannondale Si Hollowgram, 22/32/44
Chain SRAM PG-991 9-speed
Rear Cogs Shimano XTR, 11-34
Bottom Bracket Cannondale Hollowgram Si
Front Derailleur Shimano XTR
Rear Derailleur SRAM X-0
Shifters SRAM X-0 Trigger
Handlebars FSA MK-100OS, flat
Stem Cannondale XC3 HeadShok, 31.8 mm
Headset Cannondale HeadShok Si
Brakeset Magura Marta SL
Brakelevers Magura Marta SL
Saddle Fi'zi:k Aliante Team Replica Ti
Seat Post FSA Carbon K-Force Lite
Colors Siemens Team Replica (gloss) (REP).
Sizes P, S, M, L, X
F2000 SL Specs Back Geometry
Frame Optimo
Fork HeadShok Super Fatty Ultra DLR, 80 mm
Rear Shock N/A
Rims Mavic XM819 UST Disc, 24 hole
Hubs Cannondale Omega front, DT Swiss 340 disc rear
Spokes DT Swiss Competition
Crank Shimano XT, 22/32/44
Chain Shimano 9-speed
Rear Cogs Shimano XT, 11-34
Bottom Bracket Shimano XT
Rear Derailleur Shimano XTR
Shifters Shimano XT Dual Control
Handlebars Cannondale Wind Carbon, flat
Stem Cannondale XC3 HeadShok, 25.4 mm
Brakeset Shimano XT
Brakelevers Shimano XT Dual Control
Saddle Fi'zi:k Nisene II HP Ti
Seat Post Cannondale Carbon
Colors Patriot Blue (gloss) (BLU), Tangerine (gloss) (TNG).
Sizes P, S, M, L, X
I am fairly sure that you can buy an Optimo framset from an authorized dealer.
Discussion Starter · #3 ·
oops
I should have been more specific. I meant the difference between the frames. I wanted to know if they are the same frame, with the excpetion of the 4000 SL having the Si crankset/bottom bracket?
· Registered
No difference in the frame although I'm not sure about the BB threading. That could be different, but probably not.
I don't really see any ride difference in an Optimo or Furio either. Owning a frameset of each, I cannot tell the difference in ride quality.
· Registered
Frames are the same except for the BB shell. The f4000 Si bb shell has no threads. If you want to run a conventional bb in a frame with an Si bb shell you apparently have to get an adapter. The addapter has threads inside which let you put in a conventional bottom bracket.
Somehow that inegrated bottom bracket stuff just seems like a bad idea to me.
Look here..
http://www.cannondale.com/bikes/tech/misc_components.html
for the link to the pdf of the manual for the installation of said adapter. The link is about 3/4 of the way down that page. It has a drawing that gives you a good idea what I'm talking about.
1 - 7 of 7 Posts
