1 - 12 of 12 Posts
HammerHead
bolt extractor
You can use bolt exractors (Sears or OSH). You drill a small diameter hole in broken bolt and then use extractor. However I am not sure for that small bolt they have the extractor. You can also drill it out and use helicoil to repair it
Super Moderator
Or, you can tack-weld an extension bolt head to the busted piece. Just make sure a decent sized washer separates(to prevent welding the new bolt to the boss) the old and the new bolt pieces. That's an old automotive trick.
Easy to screw up and sooo cheap to have a machine shop do it. Last time I had the problem, a small bolt broken off in the alloy body of a nailgun, the machine shop charged me for 2 minutes of time at $60 per hour for a total cost of $2, rounded up to their minimum charge of $5. $5 wouldn't even buy you a single left hand twist bit, much less make up for the time and frustration and the misery of screwing it up....
Take it to a machine shop.
What is the part? I can't recognize it, sorry, these bad eyes. it looked like a stem at first, and then......I dunno what it is. Looks like you could brag the right one with some pliers but not sure.
Good luck with that and let us know how you got it fixed.
Discussion Starter · #11 ·
update
I took the crank arm to a machine shop and they removed all three screws for $8 (and did not damage the threads, thankfully).
Thanks for the advice!
1 - 12 of 12 Posts
