21 - 30 of 30 Posts
Internal cabling is fine for the dropper and shifter so long as the frame has tube-in-tube routing. I'd prefer my brake lines outside where it's easier to deal with fluid.
I prefer mechanical over electronic because I've got enough batteries to charge in my life without adding two more.
No cables (all electronic or hydraulic).
For the love of god, could anyone really go back to rim brakes?
Rides all the bikes!
Last time I changed an internal cable housing, I was surprised how easy it was. I was dreading doing it, took me the same amount of time as doing external (because I didn't have all the cable clambs/zip ties). So, I am fine for internal. I haven't had to deal with brake hoses on any of my bikes yet. Is that something you all do that often?
I prefer mechanical shifting because I just don't like batteries on critical systems. I don't need a GPS to ride. I don't need a power meter to ride. But I don't want to have to rely on a battery to shift. All my bikes are mechanical. I think electronic is cool, but, I just don't want it.
I grew up on points ignition and multiple carburetors. I currently drive a 1995 diesel and a 2003 motorcycle, so I already deal with a mix of old and new.
Brake hoses need zero maintenance. Once they’re cut to length and set up they’re good until you happen to damage one in a crash or other mishap. You do need to bleed the brakes on occasion but it’s usually a simple task.
Disgruntled Peccary
Yep, but man its so much easier to do that initial bleed off the bike. I also just dislike the fiddling with it, mostly because I don't care about the aesthetics.
Single Track Mind
Full internal routing: Just as easy to deal with as external routing, but only needs to be done 1/2 as often. This equals a net gain IMHO. As for brake lines, I have never had to mess with them. I even upgraded the brakes and used the same lines. They are literally set and forget.
I am fine with either mechanical or electronic shifting; though, I haven't tried electronic shifting yet, so that opinion could change. But, I see an avalanche of satisfied AXS users compared to just a few legitimate complaints.
And, I'll take new all day long. There is no foreseeable reason why I would ever go back to rim brakes. I do not miss that nefarious feeling of seeing a sharp bend at the end of a steep downhill, grabbing two handfuls of brake, only to feel the wheels spinning through the pads as if they weren't even there- forcing me to plan a low-side slide just to keep from tumbling down the mountainside. Totally good with bleeding my brakes once a year whether they need it or not.
That is true. On my most recent hydro brakes I haven't had to do a full bleed fortunately. I was able to trim the hose to length at the lever then do a lever bleed.
21 - 30 of 30 Posts
