1 - 2 of 2 Posts
How do i remove the cranks on my Race Face Evolve XC setup? Is it necessary to remove the chain? The cranks barely spin. I have no idea what the problem could be!!!!:madman:
No, you won't have to remove the chain, just drop it off of the chainrings before you try to remove the cranks. It sounds like there is a problem with your Bottom Bracket, assuming the cranks used to work well, You probably got some water in there and will need to look at getting a new bottom bracket for ISIS or square taper style, or new bearnings for the new-style cranks with the outboard bearings.
Check out what Park has to say: http://www.parktool.com/repair/byregion.asp?catid=59&imageField2.x=22&imageField2.y=14
1 - 2 of 2 Posts
