I recently purchased a V3 Following and got it assembled. I’m using the Shimano XT M8130 superboost crankset with Chris King bottom bracket. and have run into a problem. The Shimano chainring (30t) would rub on the rear swing arm when installed, just slightly. The assembly bolts on the chainring its self, would just rub. I ended up installing a 1 mm spacer on the drive side to resolve the problem. However, even with that, the chainring would rub excessively on the lower most portion of the chainguide ( the bottom of the mounting bolt bracket area). I ended up needing to remove the chianguide for it function. The chainline seems fine, it just seems like a problem with the width of the Shimano chainrings due to how it made. Have you run into this problem before? Do I need to use a non-shimano chainring? I’ve reviewed all the install documents from Shimano to make sure I had the spacers in the correct spots and orientation, and double checked the bottom bracket install instructions as well to make sure that was correct.
I've measured by chainline at about 57mm or so, (Evil states it should be 56.5mm, which makes sense with the 1mm spacer I added.
Has anyone else run into this? Which chainring is Evil using on there XT builds? The CRM-85?
