Bikeeveryday said:
Every winter, my brakes lose power. And they start squealing like they are contaminated. When I look at the back of the pad, there is a wet ring. Looks like brake fluid. But no matter how many times I rebuild my avid juicy carbons, every winter it seems like they leak again. Could it be because I'm using castrol gt lma fluid? It is not 5.1, it is dot 3/4. The brakes will be fine all summer, but when it starts to get cold (20 degrees Fahrenheit) they seem to leak.
What should I do about this?
Yup brakes will leak a bit in the cold 20F is pretty warm for this to happen though....
My XTR's can get way down -20 C before that may or may not happen....
First thing that happens is the fluid contracts, so the reservior gets low, then a little bit of air can get in the brake...
Then I will always get some snow, salt or muck on the rotors....
Then I will pull really hard on the lever to get them to stop...
Bingo I get a leak again only if it is really cold...
If on the other hand I fill the reservior, when it is a little cold and right full...the problem tends to be solved....
Don't know squat about your brakes though.
