allen keys 1.5-10mm
torx T25 screwdriver (for 6 bolt rotor bolts)
cone wrenches
cone wrenches
Kits are good depending on the range of years of bikes you own. I have a kit, and I dont think I have used all the tools yet.Jim311 said:I recommend picking up a cheap "kit" that runs in the 35-40 dollar range. A wide variety of commonly used tools.
if you already have one of the following, they can also do a decent job:sanjuro said:Without a cable cutter, there is no way to have a clean cut of housing and cables.
.1+derby said:Buy them as you need them.
It is not the size of the pliers, but having a diagonal edge that cuts like scissors.boomn said:if you already have one of the following, they can also do a decent job:
really big pliers usually have enough leverage to cut the cable in one quick and clean motion
dremel with a good blade does ok on cables and great on housing
I guess I've been lucky with my pliers and didn't realize it. I mentioned the size (really the handle length is what I meant) because the smaller pliers I have with the same cutting edge don't work as well. With more leverage on the really big pliers I can snap through the cable almost instantly, instead of cutting with some hesitation with the smaller ones that leads to me hacking up the last part of the cutsanjuro said:It is not the size of the pliers, but having a diagonal edge that cuts like scissors.
Pliers typically have a few small chips on their cutting edge, so one or two strands will not get cut.
Housing would probably work, but I would use a paper cutter or even a razor blade if I didn't have a cable cutter.
