1 - 13 of 13 Posts
· Adventure Mapper
Hi guys and gals. Looking to race my first endurance race this year.
Got a new saddle and figure that upgrading my other contact points is probably a good low cost/improved comfort place for me to invest $.
I currently use an old set of Oury grips that are okay, but with multiple wrist fractures from my earlier years of skate/snowboarding, I am concerned about my wrists enduring, not to mention the sore hands I occasionally have after long rides (Oury grips have improved the latter slightly).
I was all set on purchasing the Ergon GP1 grips, but then thought about my adjustable front fork. It goes from 100-130mm and I use the whole range on every ride. Would changing my forks travel have any bearing on my preference of the Ergon grips' angle? Which fork setting would I prefer it setup for if so?
Thanks.
· Banned
IMHO , travel would have little to no effect on grip angle preference. Hand position is more closely coupled to seat/body position as I see it .
· Registered
I think your question about the Ergon grips and an adjustable travel fork is a good one. I've been using the GX-2 Carbon since they first came out - love em'.
The bike I ride/race the most has an adjustable fork that switches from 115-140mm. I find that I adjust the travel back and forth between the two fork positions quite a bit during a 24hr race. IMHO the two positions have a preferred 'perfect grip setting' and it is a bit different for each one. But, there is a 'sweet grip spot' that covers both fork settings and it's hardly a compromise.
FWIW, I think the saddle is a much bigger issue for adjustable travel forks. Not sure if you have looked at it yet but the saddle position (nose up or nose down alignment) is a pretty big deal if you are going to be in a really long race and switching between the travel settings. Finding the happy medium for the saddle will take a bit of compromise, if you haven't played with it yet you should take a look at it as soon as you can.
· Adventure Mapper
Discussion Starter · #8 ·
Thanks for the thoughtful reply! That is super helpful. I agree that the saddle angle is huge on the adjustable travel forks. I am still messing with the recently purchased saddle and its angle. I think for my last saddle, I got it set up with a bubble level put on top of a hard bound book which was sitting on the top of my saddle. I set it up level when my fork was in the "climbing" or short travel (100mm for my fork) setting. I think that worked pretty good as my cockpit to saddle length is shorter than most who are my height, yet I am always seated for climbs. Maybe I should try setting it to level when I am halfway between the min and max travel settings for my fork (115 mm). Maybe when I get the Ergon grips, I should set them up at this halfway setting too?
· Registered
My advice would be to get both saddle and grips roughly where you think they should be and then grab an allen key and head out for a long ride to do the fine tuning.
I think you'll find the grips will be easy to sort out, just bracket it in until you get where you want to be. If you are OCD (ok, I admit it, I am a little OCD) the grips will drive you a little crazy as you make microscopic adjustments back and forth and eventually you will just have to say good enough - at least that's what I do. ;-)
For the saddle I think it boils down to which position you are in the most. I have my cockpit to saddle set up short as well and I quite like racing in the 140mm setting, it agrees with my racing style and my 47yr old back. It's hard to describe exactly what I do but it goes something like this...
- Set the saddle to my 140mm setting.
- Tap the nose of the saddle down 'a smidge'
With this saddle position I don't feel like I'm falling too far forward or loading up my traps/shoulders too much when I'm in the 140mm setting. So I'm basically neutral with a very slight saddle nose drop. When I switch down to the 115mm setting I have enough saddle nose drop that my taint isn't crushed by the pelvic area rolling forward effect.
Make sense?
· Adventure Mapper
Discussion Starter · #11 ·
staylor said:
Make sense?
Totally. Good advice. I think I would be racing a little more towards the 100mm end of the adjustable travel though. Bombed a downhill super fast and realized on the next incline that I was still in 100mm mode on the fork. Came back around the second lap and made sure the fork was @ 130mm and it (maybe just me being tired) seemed a little more slugish, less like I was railing it. That being said (sorry, this is a little off topic now), I realized that I really need to use the entire range of my fork's adjustable travel more often. I usually just change it for the steeps, setting it to one extreme or the other if I am heading up or down.
I guess I really need to figure out the middle ground a little more and adjust to suit that as best as I can. Kinda like knowing the middle chainring (on a triple crank) gear combinations so well that you only choose the extremes (granny and big ring) when you have to...not the best analogy, but that's kinda what I am realizing may work. Does THAT make sense?
· Adventure Mapper
Discussion Starter · #13 ·
KERKOVEJ said:
GP1 is heavy. Look at the GX1 or the GS1. GS1 comes to market in mid-March 2011. GS1 is a softer version of the GX1. Been testing it for about 3 months now. It is intended and designed as a 'endurance' race grip. My teammate, Alban Lakata, used it this summer to win Marathon Worlds.
</a>
</a>
So its mid March 2011. Where should I look to get the GS1 grips?
1 - 13 of 13 Posts
