1 - 5 of 5 Posts
Can anyone offer a comparison to the gearing of the 1x10 set up on the Epic Expert Carbon EVO 29’r ?
It is listed as 11-36t. I have no idea what that means. I currently run a 3x9 that came standard on my 08 Stumpjumper so could it be compared to the middle ring ?
It comes with a 34t ring on the front which is 2t larger than most middle rings on a tripple. The rear has the 11-36 which is 2-4t larger on the low end than most 9s (most are either 11-32 or 11-34) cassettes. The crank can handle a 32t ring on the front if you'd like.
Discussion Starter · #5 ·
Yea I was not thinking clearly... I was looking at the cassette specs when I listed the 11-36.
Thanks for clearing it up.
Crank Set - Custom SRAM Carbon S-2200, 34t single ring, PF-30, removeable spider, S: 170mm, others: 175mm
Does this mean I can change out the rings based on the terrain I plan to ride?
1 - 5 of 5 Posts
