1 - 8 of 8 Posts
Hi all
Im after some advice i have a 2008 s-works epic with the standard xtr crank and hollow tech BB
Ive managed to lay my hans on a MTB specialized fact carbon crank with 2 rings which i beleive is the same dimensions as the road version only wider, I would like to fit this to my epic has any one done this before if so how.
many thanks in advance:thumbsup:
lees-works said:
Hi all
Sounds like you have a set of their road cranks, not MTB cranks.
bhsavery said:
You can't.
The "FACT carbon" crank uses a BB30 bottom bracket. Your 2008 epic has a normal sized bottom bracket. There is not an adapter.
I thought Specialized did their own OS standard, and doesn't use the BB30.
Discussion Starter · #7 ·
There definatly mtb cranks which came from one of there team s-works who use the bb30
Thanks for the replys keep them coming
The Zipp thread-in BB30 cups are your only hope, but the spacing/chainline may be wrong depending on which cranks you have.
If you post a pic of the spindle section of the cranks (where they join) I may be able to help.
There were a few different versions that the Specialized Team have been running over the past three years.
1 - 8 of 8 Posts
