1 - 5 of 5 Posts
Long story short: I need to replace my 180mm cranks with 175mm (among other measures) b/c of toe overlap with front tire during turns. I've decided to go with White Industries ENO cranks. Do I need to get the ENO lockring tool as well or can I get away with something cheaper? Thx.
my eno's came with the chain ring already attached, and i have had no reason to change it. some people say you can use older bottom bracket tools. i have a park tool for that reason, but i have not been able to try it yet. speedgoat has a different one they recomend.
My Ass is My Pilot
I used to make them for webcyclery and they are fairly easy i used this slightly modified bbt4. Just use the lock ring to score the three prongs then dremel them a little shorter and thinner and that should do it...any questions let me know?
http://www.parktool.com/products/detail.asp?cat=25&item=BBT-4
1 - 5 of 5 Posts
