1 - 7 of 7 Posts
the guy who owned my bike before me was running a presta valve tube in the front tire. if i wasnt to run a scrader can i just drill the hole a little bit bigger with a normal drill or is there a special tool needed. i want to do this for the convieance of carring on type of tube on rides instead of two. if you know if that is possible please let me know.
uhhhhhhhhhh, i have ryno lites and just took out the presta and put in a scraeder without any mods...................................
but there are rims that are presta specific? didnt know that
Discussion Starter · #3 ·
some one told me that
you needed to make the holes bigger but now that i remeber who told me that i probably should have not even listened to them or even for a moment though that they might be right. geuss i don't need to get out the drill.
Cynical Bystander
I just drill mine out. Some rims you can use the schrader but other ones you'll have to drill a bit. It's only shaving the edge maybe half a millimeter total, definitely not doing much.
Fine to drill if the hole is too small for a schraeder valve.
aka Jesse Palmer
On my rims there was a rubber ring that I pulled out to make the holes bigger, but I htink its too big now and **** is getting into the tire, what should I do to seal the hole?
1 - 7 of 7 Posts
