Enel Goes Plus
It all started with a flat tire. I was supposed to meet Mike and another friend for a tour of our local trails. I rushed out after work only to pull the Prime out of the sport van and find the rear flat. And it was the sort of out of sealant flat that needs a tube. And the Prime rear axle is a slow PITA to deal with, anyway...
Mike smirks, leans over and says. "Just ride my wife's bike." Okee dokee then. I'm not exactly sure what the wife's bike is, but I've ridden Lenz stuff in the past. We raise the saddle and bars, add some air to the shocks and are off. Something about "first hit is free" comes to mind in retrospect, but back to the story.
Shortly later my mind blew up. Because despite the hydro brakes I found way over powered, and the stupid push with thumb shifters, I was having more fun, more comfortably on a bike than I had in a long, long time. I think I went hoarse whooping and laughing on that ride.
Afterwords I mention in passing that I would definitely buy that frame when the time came for Jeny to upgrade.
Fast forward a few months and I get pinged by Mike that it is time. He and I come up with specs for a complete bike and slowly the parts and frame come in.
Turns out the bike is a Behemoth Plus (never heard of it actually). I have actually been living in a hole of work, kids, running, lifting weights, and occasionally riding the rigid Jones and even more occasionally riding the Prime. I have not paid attention to bikes. At all. The bikes I had did everything I needed them to do.
So I let Mike Spec the fork, rear shock, wheelset, asked for 760mm wide minimum sweep bars, and durable drivetrain with really, really low gearing.
Ended up with:
Medium Lenz Behemoth 29+ Frame (I am 6"1')
Rockshox MT3(?) rear shock with roller
bearing bushing thingies
Some Truvative riser bar
Syntace 50mm stem
Lyrik fork set to 130mm
DT 360(?) front hub laced to WTB KOM lite front. FR4 3.0 tire.
Onyx hub laced to WTB KOM Rim. Dirt Wizard 3.0 tire.
SRAM cranks with 24 Wolf Tooth bash front
X11 speed in rear with XT 11-46 cassette with twisty grip shifter.
Old 4" Gravity Dropper and Koobi Saddle
Avid BB7 brakes as it should be.
The following posts will cover my build, and break in rides of this extremely fun and interesting bike.
Ended up with:
Syntace 50mm stem
