I bought an Enduro SL Expert frame kit about two months ago, and I've never quite been able to get the front derailleur adjusted the way I like it. It shifts perfectly, but the chain rubs a lot on the front derailleur when in both the small and middle chainrings and when in the three or four largest cogs in the rear. Also, the front derailleur's inboard travel is extremely limited (even with the limit screw backed all the way out), which I'm sure has led to the chain rubbing when in the granny gear. Any ideas?
FWIW, I'm running Shimano XT M770 cranks (with the 2.5mm BB spacer installed on the driveside for 73mm BB shells) and a Shimano XT E-type front derailleur with the E-type bracket removed to make it compatible with the goofy Specialized chainstay mount.
