1 - 4 of 4 Posts
Ok.. So i am a sucker for marketing hype.....
i found this on the enduro fork seals website
http://www.enduroforkseals.com/id275.html
now i want to order a set for my 08 Mojo SL ...
but when looking at the list they have there it seems that the mojo's Reducer body and shaft changed over the years .... I have been using my 07 shock and reducer kit on my replaced 08 sl frame? Is this a bad thing?
Can anyone give some insight on this?
odd
Maybe that's a typo on the bike list...
The shock spacer specs are the same for all years of Mojo and Mojo SLs. It's just shy of 22 mm with an 8mm through hole for the front, and just shy of 40mm with an 8mm through hole for the rear.
That kit should work for the front. Let us know how well it holds up.
Hans
flow where ever you go
Looks pretty cool. The picture at the bottom of the page shows a "custom spacer, aluminum" and they say they make spacers to fit - so I imagine it should work for both mounts on the Mojo as long as you get spacers made for the rear?
Proud lame eBiker
Hans
Hey
Hans....does that mean you guys use an 8mm bolt front and back on the shock? That's a big bolt. I like it!
1 - 4 of 4 Posts
