+1 another thoughtful tweak dgc. the needle bearing and carriage looks similar to the one in CK rear hubs except a helluva lot smaller. never heard of the du/reducer wear. whatdaya think was causing it/from dwl or older turner?
I was wondering when someone was going to speak up.Dusty Bottoms said:4 DU's is called a "frame alignment problem". Take your frame into the factory for immediate inspection. Thank you.
Thanks moose.moosehead said:+1 another thoughtful tweak dgc. the needle bearing and carriage looks similar to the one in CK rear hubs except a helluva lot smaller. never heard of the du/reducer wear. whatdaya think was causing it/from dwl or older turner?
there's some here... http://www.enduroforkseals.com/id275.htmlkosmo said:Link to source, please, or just get it through your LBS?
I just started following this,Are you replacing more bushings than on you're previousTurners?[for approximately same rideing/conditions] just curious. thanks... kellyDGC said:Thanks moose.
So DB, are you saying the same for Squish too? he must have a really crooked frame according to your explanation.
As usual DB, your wrong and way off base.
I checked the frame, talked with DT about frame alignment. It is dead nuts straight. If the frame and rocker were that far out, there would be shock durability issues and a decent amount of binding. There would also be un even grooved wear inside the old DU's. None of which are the case with my bike.
Maybe 2 sets a year is acceptable for me, since I purposely ride a ton more rocky and choppy terrain than I did with the older TNT Spot. I don't wait til you can lift the seat up 1/2 inch from the slop in the reducers, I replace them when the reducers move sloppy freely in the DU, and the DU is worn looking. So maybe I will be a good endurance tester for the Enduro kit, time will tell.
Anyone remember the Intense Tracer 4 inch travel horst bike from a number of years back? It too went through DU's and reducers quickly, as do a few bikes here and there. It happens. Certain designs add to the wear of the DU and reducers.
Squish......the Enduro kit is sealed quite well, seals on both sides of the spacers. I will take a look after I get another 4-6 rides, that might take 6 weeks or so with winter tho...............Tapper knows how important a good powder day is....!!!!!!!!
I ride the same area trails, but I ride more often, and ride much rougher trails than I did with the old bike.kelly1 said:I just started following this,Are you replacing more bushings than on you're previousTurners?[for approximately same rideing/conditions] just curious. thanks... kelly
So are you saying that the premature DU bushing failures are justified?DGC said:I ride the same area trails, but I ride more often, and ride much rougher trails than I did with the old bike.
I would say that my riding has changed from the old bike to the new bike, definately adding more wear. I could see 2 sets of DU's, not 4. And the fourth one was just put in, so that makes 3 sets used up. So it would be more accurate to say 3 full sets.Mtn. Biker123 said:So are you saying that the premature DU bushing failures are justified?
How many miles? I did 2000miles conservatively on my RFX w/DHXc before switching to the CCDB, no problems. After a year and a half and over 4000 miles (on the CCDB with spherical bearing) they are still good as new.DGC said:I would say that my riding has changed from the old bike to the new bike, definately adding more wear. I could see 2 sets of DU's, not 4. And the fourth one was just put in, so that makes 3 sets used up. So it would be more accurate to say 3 full sets.
So there is a significant difference, but WHAT is the difference? Do you need to adjust shock pressure values? Better small bump sensitivity?DGC said:Instead of just posting a ride report on the original thread I started a few days ago I thought it better to start a new one so more people will see this.
I normally would not post a ride report on a topic like bearings vs. bushings but this is well worth posting about.
The Enduro shock eye needle bearing kit is well worth every penny. It took about 100 yards of dirt to realize the super low friction of this needle bearing kit. The first 75 yards was spent checking and re-checking the tire and shock pressures. I thought they were soft and low psi., nope. ***The difference is quite significant***
You will feel the difference using the Enduro needle bearing kit over the stock DU's and reducers. I had recently installed the **4th. set** of DU's and reducers this year. Time will tell with maintenance on the needle bearing kit, but consider this.....for me, the maintenance on the DU's + reducers are rediculous at 4 sets in a year, that is 3 sets too many.
If you rebuild your fork at least once a year, your King hubs the same, then cleaning and regreasing the needle bearing from time to time should not be an issue.
The weight difference is nothing, if you have your Spot set up at over 28 pounds, then a few ounces, if that, is worth it's weight in gold.
What more is there to say, this needle bearing kit kicks ass.
Sorry I did not quite get it all out back when I posted this........In the original post I was about to say the difference with much less friction is a more lively feel, the trail gets smoothed out more than with the stock Fox DU's, yes better small bump sensitivity for sure, it is smoother all the way through the stroke not just on small stuff. Full travel is easier to achieve. I also noticed climbing traction was a little better.006_007 said:So there is a significant difference, but WHAT is the difference? Do you need to adjust shock pressure values? Better small bump sensitivity?
