damnitman said:
...imperceptible performance enhancements at low speed (I am SLOW), I like to run both my tires so that the imprint "points" in the direction I am going...helps keep me from getting lost in the dark after riding for a couple hours...There isn't much of a trail "system" here in Bethel...just a BUNCH of trails that eventually go somewhere...with some Very inconvenient places to get "turned around"...plus makes it easier for the SAR guys (and gals) to find me...
I got "lost" a couple nights ago on some memory maze trails I have mostly well memorized, on a pitch black night. I took a trail I knew well in the summer, and knew exactly where I would be at the next intersection. Well, the next intersection wasn't familiar, so I took a right. If I am lost on the island, I keep taking right turns until I end up somewhere familiar. I swear I took only right turns at every intersection (about a dozen of them), and about and hour later I finally arrived at the "next" intersection I was expecting, but from the wrong direction! I looked down, and I had passed through that intersection already! Maybe I need a brighter light...
I weave often enough avoiding the groomed ski ruts that it is easy to tell which direction I was headed by the overlap of front and rear tracks (rear is on top, and cuts a tighter curve than the front).
Which Bethel? If it is Bethel Maine, have you been out on the trails that go up to the ice caves yet this year?
Oops, way off topic. I've got not much to add to the traction discussion until I flip tires, and then I won't know which is better because I will compare backwards and worn leading edges to frontwards and sharp leading edges.
