I understand that the enabler is built for a rear brake. If I use a 135 SS hub, is there any modifications that I need to do so the fat front works?
With a front brake?Velobike said:Mine was out by 2mm when installed. I haven't checked to see if it's the hub (Revolver) or the fork, but it was easily fixed by using a 2mm washer on the inside of the axle to space the wheel out further.
The only difference between a IS front and rear brake/bracket is the radial distance from the axle.Gingerdawg said:With a front brake?
I am a little confused.Velobike said:Mine was out by 2mm when installed. I haven't checked to see if it's the hub (Revolver) or the fork, but it was easily fixed by using a 2mm washer on the inside of the axle to space the wheel out further.
Wouldn't this space the ISO tab out by 2mm from the wheel?Velobike said:Mine was out by 2mm when installed. I haven't checked to see if it's the hub (Revolver) or the fork, but it was easily fixed by using a 2mm washer on the inside of the axle to space the wheel out further.
Same setup as mine.green mt. boy said:Enabler is 135.
I can use a SS hub (Revolver brand).
I can use my front brake w/adapter for stopping.
If I am incorrect please say so.
You still have not clarified 2mm which way.Velobike said:Same setup as mine.
It's 2mm out.
Ah, sorry.shiggy said:You still have not clarified 2mm which way.
Correct. To run a 135 front hub on an Enabler, you need to file/machine the caliper adapter down about 5mm (to line the caliper up with the rotor) and source some 0.5 mm wall tubing with a 9 mm ID to press over the axle ends.smoen81 said:So if i'm reading this correctly, I cannot run a 135mm spaced front hub (paul, speedway, surly, etc) in the enabler? I have to run a rear hub with front disc brake? Thanks for the clarification.
No, the Mukluk comes standard with a Surly rear single speed hub in the front. Surly doesn't make a 135 mm front hub. The Enabler is NOT front hub compatible without the modifications I mentioned above.Toni Lund said:Standard Mukluk has Enabler fork and Surly 135 mm front hub. My forthcoming 907 project will also have the same. So Enabler IS also front hub compatible.
Ok, very good to know.Andy FitzGibbon said:No, the Mukluk comes standard with a Surly rear single speed hub in the front. Surly doesn't make a 135 mm front hub. The Enabler is NOT front hub compatible without the modifications I mentioned above.
