The printing on the spring is just the max stroke, in inches, that the spring can take. The Romic is most likely a 2.25" stroke with a 2.5" stroke spring, which is pretty common. My 2005 frame came with a 7.875"x2.0" Romic(with a 400lb x 2.25" stroke spring), but I swapped it for the 2.25" stroke shock and definitely preferred the ride. In reality the shock was a hair longer than 7.875" though.
Measure the push rod length if you want to know the stroke length of the shock. (The distance from the bottom of the spring to the bottom of the shock body)
