Hi
For the element 70, 2008.
Are this the proper bearings for the frame?:
6001 2RS MAX
6901 2RS MAX
The pdf file:
http://www.silverfish-uk.com/cms-files/resources/45-ee345ed9d5944ee61f88ca22b542da25.pdf
I think it`s a little wrong at the page where the exploded diagram of the element is displayed, because it says 61901 -2RS bearing type, so are they correct? because if that`s true I can`t find the correct number at the enduroforkseals.com max bearing page.
BTW, are these : http://www.enduroforkseals.com/id169.html , bearings better than the stock ones? Are they easy to put in place? The two listed below are the one`s that match the frame, aren`t they?
Are there any other webpages that sells the rocky mountain FS hardware, like IGUS bushings and the 12mm screws?...besides the LBS, obviuslly,
Thanks guys!
bye
6001 2RS MAX
6901 2RS MAX
The pdf file:
Thanks guys!
bye
