Using sealant in Kenda's will officially void the warranty. They may take care of you anyway though.
point taken.mobaar said:Using sealant in Kenda's will officially void the warranty. They may take care of you anyway though.
Really ? so kenda doesn't make tubeless tires then ?mobaar said:Using sealant in Kenda's will officially void the warranty. They may take care of you anyway though.
They make UST tires, but unless the tire is specifically labeled "SCT" (sealant compatible tire) then using any sealant will void the warranty.adumesny said:Really ? so kenda doesn't make tubeless tires then ?
I'm using a El Moco 2.35 on the front which I recently converted to tubeless (a real pain as the edges on my old tire didn't want to seal without a lot of work, and still leak small amount after a few weeks). Hoping I won't get a delaminate issue...
On the back, I've been running cross mark LUST 2.1 with 0 leak issues for a long time now. But it's time to change it
