1 - 4 of 4 Posts
Can this work on a 15" frame or would it mess up the geometry? The weight of the rider is only 110 pounds if that makes any difference. It will be transferred from a similar size Motolite.
Bandolero
Reptiles and Samurai
I've got a 15" frame. I can't imagine an El Ciclon with anything less than a 160. It just doesn't seem right. Man up, Nancy and spring for the bigger boinger.
Ultra Ventanaphile
Ciclon's designed around a 140 fork.
Can it work? Sure, but here's the draw back, you're gonna lower the BB about 10mm or .4". The Steering angle will be a full 1 degree steeper as well.
So you'd be looking at 69.3 Head angle and 13.2 BB (With 2.0 tires), One solution is to run a fairly High Volume, 2.3/2.4 front tire and a 2.1 rear. That will help some.
Also what 120 fork? RS tend to be taller than FOX's and I believe the A to C used for the Ciclon is Fox, so the effect might not be as severe if you are using an RS fork.
The Bubble Wrap Hysteria
Yes, the Ciclon is designed for a 511mm A2C. The Fox 140 is 510mm and the RS 140 is 519mm. I had a Revelation U-Turn on my Ciclon and it felt good at 130mm which is 509mm A2C. It now has a Fox Talas 140 and feels pefect.
I had a 2007 Ciclon with a Fox Talas 100-120-140 and I often road it at 120mm
1 - 4 of 4 Posts
