Is anyone out there running a Fox DHX Air shock on their El Chamuco?
If so, let us know what you think.
You will need to check clearance on your frame. They fit a large OK I have not tried it on any other frame size.heckler_asx said:Is anyone out there running a Fox DHX Air shock on their El Chamuco?
I have a large so I should be ok. So how do you like the ride of the DHX Air?ajr said:You will need to check clearance on your frame. They fit a large OK I have not tried it on any other frame size.
I like the DHX air and the guy who tried it did to. It is easy to set it to ride the way you want.heckler_asx said:I have a large so I should be ok. So how do you like the ride of the DHX Air?
