1 - 6 of 6 Posts
· Registered
Yes. At least the Race variety with Poploc. Do a search. Issue solved with +4mm CK crown race courtesy of Sherwood himself. I have one on my personal El Cap with Reba. Works gloriously. $25.
· Registered
Discussion Starter · #3 ·
Thanks, I was searching the 80 to 100mm conversion and came across the problem last night and went directly into panic mode.
Are these available from CK or Ventana? I also saw Speedgoat has a conversion to turn the external floodgate to an internal floodgate which they say buys you 5mm. I hope this Reba is worth it it seems like alot of work to make a fork work.
Another question, did you remove the lowers entirly when you converted your Reba, or did you push the air chamber through the top cap to remove the spacer?
· Feeding your addiction
They are available through Ventana or Ventana dealers (I have them in stock). That's a much easier/better solution than having to change the Floodgate adjuster.
Larry
Mountain High Cyclery
[email protected]
dogalope said:
What would be the best way to order one from you?
Got your phone message, I'll call you tomorrow.
Larry
1 - 6 of 6 Posts
