1 - 7 of 7 Posts
Hi, I have a 2021 Pike and it's coming up on the 50 hour service, was given a new jug of 5WT WPL oil, any concern with using this vs the Rockshox recommended 0w-30? I've never done a fork service but it seems pretty straight forward.
Boom bap ambassador
For lower legs that will work just fine. Damper oil would be thinner so something like WPL 2.5 would work for a damper rebuild.
Rockshox 0W-30 is listed with a cST of 47 or so at 40C which is thicker than WPL 5W at 18 [email protected]
Some people on here get all worked up about this or that holy grail of oil but in my experience with my own forks I haven't seen a difference using a less thick oil vs a thicker oil for lower lubrication.
Doing service and using a quality oil is better than using crap oil/holy grail oil but only doing service once in a blue moon/hundreds of hours I reckon.
WPL 5WT is a thin damper oil. It lubricates well but doesn't cling well and in the lowers you want a thicker lubrication film.
WPL's 20WT is suitable for lower leg service and a substitute for the 0W30 that RockShox specifies.
  • Like
Reactions: karpiel
I really do prefer Rockshox 0w-30. As the folks above say, not all oil is made equal. Not all 0w-30 is the same. I've tried different 0w-30 and it's negatively impacted the fork performance in the lowers as it didn't cling as well.
Sent from my IN2023 using Tapatalk
In my 35mm Revelations, I have used RS 0w30, Maxima fork oil 20wt ([email protected]), Penrite Pro5w40 ([email protected]) and Husqvarna bar and chain oil ([email protected])
I have use each of these once and I'm going to probably try them all again (as I've changed/improved other parts of the fork)
I never go over the 50hr recommendation and sometimes change well before that.
IME I rate these oils in the following order.
Husqvarna.
Maxima.
RS.
Penrite.
1 - 7 of 7 Posts
