1 - 2 of 2 Posts
I am having the same exact issue and I can't get a good spot for the cadence/speed sensor to work. I am going to try installing right over where the brake line is held because it seems that will be the best spot to put it but I just need to find a way that the sensor can be hold pretty good to avoid it moving around. Like I said I try this tonight and I'll let you know if it worked.
1 - 2 of 2 Posts
