I see that when I START the unit and then STOP, leave it powered on, and then START it again. It wants to connect the two parts as a single ride.
I'm a little confused by your short description as to what you actually do and don't do with the GPS at home and the trail head. Are you riding or driving? When do you turn it on? When do you press start? Are you resetting the data between rides? If you do a ride, turn the unit off, then turn it back on and press start, it keeps recording like it is a single ride. You need to press and hold the Lap (Reset) button and let it do the 3-2-1 countdown to record separate rides.
