You just answered my question without me asking it.
I just got a 705....and was wondering if there was a speed only sensor for my mtb.
The 500 will make use of a speed sensor, the 705 will not, unless you turn off the GPS or it totally looses signal, according to the manual. In the Edge 705 manualthe mayor said:You just answered my question without me asking it.
Cadence data from the GSC 10 is always recorded.
The speed data from the GSC 10 is only recorded and used for distance calculation when the GPS signal is weak or the GPS is turned off.
Ok...so the 705...if I'm reading the other posts correct...will be inacurate off road because of hills and tight turns? I thought the sensor would fix that? ( or is that just with the 500?)slocaus said:The 500 will make use of a speed sensor, the 705 will not, unless you turn off the GPS or it totally looses signal, according to the manual. In the Edge 705 manual
Read page 40 on the right hand side:
Not inaccurate, in my experience.the mayor said:Ok...so the 705...if I'm reading the other posts correct...will be inacurate off road because of hills and tight turns? I thought the sensor would fix that? ( or is that just with the 500?)
I did see another thread where I believe you said you used software to correct the mileage/altitude variances.
D'ooh! I've got to strap it on my bike and just do a ride and figure it out....I'm sure I'm over thinking the whole thing.
Just keep both hands on the bars and pedal, keep your eyes on where you are going; do not take one hand off to play with the gadget on the stem and you will be fine.the mayor said:Slo and Nate,
Thanks for the detailed info.
I usually find forums to be a train wreck.
You two have restored my faith in humanity:thumbsup: but I'm sure that will all change when I leave the house.
