1 - 2 of 2 Posts
Hello,
I've read some of the Edge 305 posts. I have a friend who just bought one, he is having some discrepencies on mileage.
I'm looking for some sort of bike computer / altimeter / hrm / gps option that is accurate, high enough sampling rate I suppose is the issue there?
Could you please expand on what the usefullness of this product is if its not giving correct info. I was considering just using a HRM and a cycle computer with a GPS for altitude and elevation gain. But I'd like to combine them for ease of information sake.
Please point me in the right direction. Thanks for your help.
Matt
Gps
I have an Edge 305 for my bike, and a handheld (1200XL). I would be more prone to accept the GPS receiver's mileage (and/or speed) than any other method. Until the 90's, accuracy was degraded. After the fall of "the evil empire", the dither was turned off. Even a low end receiver offers good accuracy. Altitude is the GPS receiver's less accurate reading. Odds of having a sat directly over ur head (at the time u need ur altitude reading are poor). Lat and Long readings are much more accurate. The Edge 305 has a baro sensor (air pressure) to beef up the altitude reading. The longer u hang around a spot, the more readings ur receiver will get. GPS message is sent every second. This=more accuracy. U can look at Wiki for more information. I was trying to "keep it simple". I was on the team that designed and tested the GPS system.
1 - 2 of 2 Posts
