You know you want 'em. I even shined 'em up real pretty fer ya...w00t! said:Is there such an animal?
Or should I just set my sights on scoring a set of hollowtech cranks and homeboy's new EBB?
btw, what are "hollowtech" cranks?
Thanks.
Well...I do want 'em, but I still don't even know what "hollowtech" cranks are and I still don't see how they install into that EBB.forwardcomponents said:You know you want 'em. I even shined 'em up real pretty fer ya...
I will give it a shot. First of all, Hollowtech has nothing to do with the bottom bracket. It is a feature of Shimano cranks to make them lighter and stiffer. They are actually hollow in the middle. There is no EBB that will fit into a standard MTB frame that will fit a square taper BB. The EBB above and the Trickstuff eccentric will only work with the newer outboard bearing crank/bottom brackets. Most crank manufacturers use this system, and most of them allow you to use a crank form one manufacturer and a BB from another. The important thing is 'outboard bearing'. FSA, Truvativ, Race Face, Shimano, Surly all make cranks using this system, and probably others. If you want to use the above EBB, you only need to purchase a crankset, as the EBB will be the BB for the system. I hope that makes sense. Good luck!w00t! said:Well...I do want 'em, but I still don't even know what "hollowtech" cranks are and I still don't see how they install into that EBB.
It's not that I'm a total dummy, I've replaced my own BB and stuff, it's just that all this bike stuff is pretty dang cliquey to a n00b and I haven't got the time to fark around with learning about English and Euro and BMX threads and 68 this and 73 that and Campy this and Square that and which Park tool to use before the Winter Solstice and whatnot. It's bollocks just trying to figure out which parts to buy.
Here's a quick summary:w00t! said:Well...I do want 'em, but I still don't even know what "hollowtech" cranks are and I still don't see how they install into that EBB.
Fair enough. There are many options, and this is another one.boomn said:time for some devil's advocate options!
This EBB costs $125 plus about the same for a new outboard bearing crankset equals about $250 for the conversion. This does not include the new BB tool you will need.
For about the same you could upgrade to a nice steel SS frame. Its actually a bit less, but you will need a seatpost clamp. You could also possibly need a different size seatpost (27.2mm) and/or a different size bottom bracket if the shell is a different width.
A third option is the Yess ETR-B, as reviewed here. Based on user comments (and the concept behind the design) it is supposedly the best tensioner out there. ETR-B is $70 shipped. However, I think you would also need an e-type bb to use this with your existing crankset. I don't know the details on this one.
All good points. My info was really meant to be w00t-specific as I know he has a budget, would need a new crankset, and has a good bike but not the latest uber-frame eitherforwardcomponents said:Fair enough. There are many options, and this is another one.
Lets look at the options you outlined. Some new frames can be inexpensive, but are they really the frames you want? This EBB allows you to use any frame at all, including one which you may already have.
The EBB tool is free, and it is included with the EBB.
The YESS tensioner is undoubtedly a fine product, but not everybody wants a chain tensioner. This EBB is for those people who want a clean chain line.
A new crankset? Maybe. Many people have one already, and might want to try it on a different frame.
This is just one more option among the many already out there such as the ENO, the Exzentriker, the tandem EBB (Bushnell, Carver or Cannondale), horizontal/track dropouts, and others I may have missed.
Whatever works. It's all good.
Cool. Just throwing it all out there, but it sounds like you have a good plan.w00t! said:Thanks for the explanations, gents. I'll come back and have a closer look when I'm sober.
boomn, I'm prolly just gonna get an On*One 29er someday soon, and I really dig the aluminum Jamis frame I have now, so I think EBB is the way to go. I was interested in the Yess ETR-B, but I don't have the BB for it and I'd probably just waste it on a rock anyways.
ENO hub is another option, but for whatever reason, me no likey. I dunno, can't explain it. I guess if I was gonna get some fancy hub it'd hafta say Paul on it.
I just thought of somethin'...once I get my Inbred 29er I'll probably lose interest in this bike.boomn said:the Inbred 29er rocks btw:thumbsup:
