The initial design goal was to make a small housing for Quazzle (lux-rc.com) light engines from a solid block of aluminium. The product evolved into a universal housing which can be used with Quazzle modules or any other LED/optic combo which doesn't exceed 24mm in diameter and 19mm in height (driver compartment - 7.5mm height, e.g. MaxFlex).
Here is the final result:
https://www.easy2led.com/
The kit includes:
The kit weights 45 grams
Length - 42mm
Outside diameter - 35mm
This topic is open for discussion and suggestions.
The kit includes:
- Lamp body
- Rear cap - 2mm thick aluminium
- Front tempered optical glass with water repellent coating
- M4x10 titanium bolt
Length - 42mm
