Slowly upgrading my Ripmo. I just took off the NX RD that came on my build and put on an XO RD. I have it working okay but the B-limit screw needs to be all the way screwed in, it could probably use another turn but its maxed. My NX RD B-Limit screw was only about half way in, sat right in the middle... Just seems wrong. Anyone have any insight here? I am following the Eagle instructions… the Instructions act as if the 50t ring and the RD Pulley wheel are worlds apart when installed and you need to adjust the B-Limit screw to wrangle them closer together which is the exact opposite from my situation.. I have to spread them apart as much as it can go to even get them to keep from touching. I can't figure it out…
