anybody know how to align the E150 fork correctly.....I did a service and slick honey treatment but the fork has a ton of stiction and my thinking is that it isnt aligned in the crowns correctly. Thanx
forker said:I don't mean to hijack your thread, but I'm also having a similar problem. I used Slick Honey grease with 20cc Fox 7wt High Performance Suspension Fluid (each side) and soaked the foam wipers in Fox Anti-Friction Float Fluid. There is now a lot of friction for the first inch or so when I compress the fork for the first time after its been sitting for while ... but then it gets smooth - a little smoother than before I took it apart. I've tried adjusting the position of the right side on the axle, but there is still more stiction than I'd like. The bike is still pretty new, so it may not be broken in all the way yet.
Does this sound similar to the problem you are having? What type of oil did you use?
i have really tested many different fluids on many different forks , ----and the fox anti friction fluid will add a ton of stiction when you use it to soak the wipers on an e150.--forker said:I don't mean to hijack your thread, but I'm also having a similar problem. I used Slick Honey grease with 20cc Fox 7wt High Performance Suspension Fluid (each side) and soaked the foam wipers in Fox Anti-Friction Float Fluid. There is now a lot of friction for the first inch or so when I compress the fork for the first time after its been sitting for while ... but then it gets smooth - a little smoother than before I took it apart. I've tried adjusting the position of the right side on the axle, but there is still more stiction than I'd like. The bike is still pretty new, so it may not be broken in all the way yet.
what makes the difference is what oil is in the fork that will mix with the grease or thicker lube . ( and you do not want to thick of a lube ---like a grease )PB Matrix said:I have done a test, one seal packed with Slick Honey, the other seal packed with Dow Corning # 33 Extreme Low Temp Bearing Grease Light Consistency. The Slick Honey lasted about 5 rides or 10 hours before it was completely gone. The Dow 33 is still going after 3 months of at least 3 rides a week.
i have not used the buzzy's 7 wt 0il ---( as with most suspension oils it is more than likley a repackedged oil from maxima , belray or fox. ---)Clint Burke said:Kelstr,
Instead of honda HP5, what do you think of Buzzy's 7wt oil? Does it really matter what brand as long as it is the right weight? For the record, I am waiting for a dampening cartridge from specialized, but I slick-honeyed up my fork and rear shock and used Buzzy's 7 wt oil. I haven't gotten a chance to ride it yet (still waiting on the part), but I can already tell a difference. Also, when I took it apart it was bone dry!...wtf
Thanks for all the suggestions.
Clint
