1 - 8 of 8 Posts
· Registered
Hey guys
I've recently installed some E13 TRS All Terrain tyres. It's my first experience with this brand. I've used Muc-Off sealant and the tyres continually weep sealant through the sidewalls and go flat very quickly during rides. I've re-taped the rims + checked the valves and the leak does appear to be through the sidewalls. I've ended up using an absurd amount of sealant in an attempt to get them to hold air, with no lcuk.
Anyone had similar issues with this brand? I wondered if perhaps the Muc-Off sealant is not compatible with these tyres. I guess I'll try my luck with some Stans sealant next.
· Premium Member
Run several of their tires, never had an issue with sealing with Orange Seal.
  • Like
Reactions: Paranoid_Android
· Registered
Don't have experience with the e-13 tires, but I used Muc-off sealant once....and never again. Terrible...they might as well call it "leakant". I'll go one further, I got a Muc-off gift pack (sealant, lube and something else....can't recall) and it was all terrible. Orange or Stans are the only one's I'll use.
· Registered
If you're 'thrifty' like me, Truckerco latex off ebay is also an option, I've had good luck with that for years now. I've had specialized tires that weep through the sidewall (Control casing), but not enough to lose pressure very quickly. Most others I've used haven't weeped much, if at all. Are your sidewalls noticeably thin?
1 - 8 of 8 Posts
