You're not going to find a guide that you can rotate enough to hit that bottom pulley. It should work ok. the problem is going to be the first time you go over a log and bash that pulley on it... say bey bey to it. I talked back and forth with intense and they recommended talking to MRP, but would not give me a specific model that would work properly... mainly because there isn't one. MRP told me to go with the G2 mini with the ibis mojo boomerang due to its bigger angle, but even it just barely hits the chain at the bottom pulley, and I've already broken the bottom pulley due to it being lower than the bash guard. my next option once this one is totally crap will be the MRP 1.X guide .
I know you are using a front derraileur, and from what I've learned, there are no options for it due to the lower linkage
