simple
MB Action sucks and R.C is a Tool.
any questions?
any questions?
RC was suggesting bikes with slacker head angles. The steep head angle of the MKiii currently doesn't qualify for superior technical downhill geometry, and the Ibis would qualify but is not availble yet.westin said:Q. Hi RC. It's time for a new bike. I live in north east PA where everything seems to be straight up or down. I ride just natural terain with no big drops or jumps. I am looking for an all mountain bike in the 2 to 3K range. My choices are the SJ pro (I know that one is streching the budget), trance, reign, IH mkIII from LBS or IBIS, comencal meta 5, or Blur lt from mail order. How would choose for my area? Also when are you going to test the Iron Horse? Should it be very similar to the Ibis? Thanks for the great mag Jim
Jim/mbaction.com - 6/25/2006 7:01:30 PM
A. RC: You'll like a bike with a slightly slacker head angle than the Specialized to handle the technical descents in PA. Get the Santa Cruz Blur LT or the Comencal.
Having ridden nearly all the more recent designs, I agree with RC's answer.westin said:Q. Hi RC, I own a circa yr.2000 Intense Tracer. I recently got the shock "Pushed", bearings replaced and bought an OE closeout of an '05 Talas RLC fork. I know you own a Tracer yourself. I want you to give it to me straight; how does that bike, with the shock upgrades compare to the current crop of 4-bar linkeages and more modern VPP and DW-link designs? Are the modern designs really that much better? I just can't afford buying a new bike every 3-4 years!
mikeder/mbaction.com - 6/24/2006 7:33:08 PM
A. RC: I still ride my Tracer--it's a great performing XC machine and it only suffers because it lacks the travel of modern trailbikes. I run a four-inch Fox X-fork and that is about the maximum travel up front that you can use while maintaining its steering geometry. Keep your Tracer until you decide to buy a five or six-inch travel machine.
I'm hoping this will materialize from Iron Horse. I want 5.5 in. of travel also. I still think this would be the ultimate trail bike(5.5 in. and under 6.5 lb.).derby said:The '07 MKiii should match or better the Tracer in all categories, but currently there are still some areas the Tracer is superior.
And the specs for the lighter and slacker steering and wider tire clearing '07 MKiii should produce the second bike in all ways better than the Tracer for mountain trail riding.
- ray
Ray,derby said:RC was suggesting bikes with slacker head angles. The steep head angle of the MKiii currently doesn't qualify for superior technical downhill geometry, and the Ibis would qualify but is not availble yet.
Annd owning a Tracer for over 4 years now and demoed the Mkiii (Hollowpoint and I. F. DW-Link), I like the slacker handling adjustment of the Tracer much better than the current steep fork angled MKiii for technically rough terrain trail riding. The current Mkii is more optimized for tight corners on smoother terrain such a s DS racing or singletrack without larger obstacles. Perhaps a 6 inch fork on the current MKiii could better match the handling of the slacker Tracer adjustment, but 6 inch forks are too big for good trail riding if you need to climb more than a few hundred feet. The Tracer can be adjusted in handling to be just as quick or adjusted to be even quicker handling than the MKiii. Pedaling the Tracer has nearly as little bob as the MKiii on smooth pavement. The advantages of the MKiii is more plush longer rear travel and noticeably smoother pedaling with even less, even no noticeable feed back in the granny on rough terrain than the very smooth pedaling Tracer. The '07 MKiii should match or better the Tracer in all categories, but currently there are still some areas the Tracer is superior.
BTW, I've put large money down on the Ibis DW-link Mojo Carbon. If it shows up with the specified geometry it will the first trail bike that is as good or superior to the Tracer in all situations.
- ray
Recall though the very favorable article on the Azure. Several pages devoted to DW-link and a full page devoted to the Azure.yogreg said:MB Action sucks and R.C is a Tool.
any questions?
Yes the slack mode Tracer is about 70 degrees, same as the MKiii. But the Tracer slack setting seat tube angle is about a degree slacker at 72 degrees than the MKiii, so the rider isn't over the fork as much with the same fit. The Tracer has 1 inch less travel to dive into when riding steeper downhill or braking hard. So the limits of handling is about 1+ degree slacker compared to the MKiii when handling is pushed towards the limits.westin said:Ray,
All great comments, as usual.
I thought even in the slack mode the Tracer's HA was 70d, and in regular/steep mode it was 71 or 71.5.
For my preference, I could not get used to the high bb of the Tracer (I don't ride tons of logs and rocks and such where a higher bb would be beneficial to prevent crank/pedal bashing that I sometimes get on the low-slung MKIII).
I wanted more travel, and mine had the stock RL Float. I figured in the price of PUSH...and when the MKIII Team frame/headset/post/saddle came along I could not pass up the $500 price! New. PUSH'ing along would've been close to $200 when all was said and done with postage.derby said:Yes the slack mode Tracer is about 70 degrees, same as the MKiii. But the Tracer slack setting seat tube angle is about a degree slacker at 72 degrees than the MKiii, so the rider isn't over the fork as much with the same fit. The Tracer has 1 inch less travel to dive into when riding steeper downhill or braking hard. So the limits of handling is about 1+ degree slacker compared to the MKiii when handling is pushed towards the limits.
The Tracer's higher BB (13.5 inches) was weird at first to me too, but I got used to it in a couple days and a few steeper climbs.
- ray
It would be cool if IH added that .5 inch to the '07 MKiii. It would then match the 5.5 inch travel and frame geometry of the Mojo. The 6Point will be heavier duty and slacker in geometry.Quattro said:I'm hoping this will materialize from Iron Horse. I want 5.5 in. of travel also. I still think this would be the ultimate trail bike(5.5 in. and under 6.5 lb.).
