Hi all,
I recently had my DVO Topaz fully rebuild (damper and air can). Everything has predominantly been fine since the service - the only minor problem that came up right away was that the bladder was not seated fully. This was quickly fixed by slightly over-inflating the bladder to get it to pop back into place.
However, recently the shock has begun squeaking upon any minor compression. I have heard suspension make some minor squishing on compression before, but that required really listening for it. I can hear the Topaz even over i9 hubs while just coasting along. It most definitely was not this loud before, even right after the service. The noise sounds similar to if I was sitting on a rubber duck while riding. The shock is leaving the usual small amount of oil on the stanchion after cycling, so I don't think lubrication is the issue.
I've spoken to DVO regarding this issue, they felt that without seeing the shock in person it would be very hard to diagnose the issue (a very reasonable disposition), but guessed that the rebound circuit might have some air in it, causing the noise. Unfortunately the mechanic that performed the work has recently moved away, leaving nobody at the shop knowing what should be done until they can contact the mechanic.
This has kind of left me in a bad spot, I'm not entirely sure what to do at this point. Has anyone experienced squeaking from a Topaz (or any rear shock) before and found a way to solve it? If I have specific steps to follow I might be able to get the shop to do something. I've continued to ride the shock as normal, but the squeaking is getting pretty annoying. I would hope I'm not doing any additional damage by continuing to ride it.
Thanks for any help.
